MX5 Eunos
Hi all whilst thumbing through some car mags in local supermarket came across intresting artical re a £1000 challange the cars involved were a Sarb,Bmw,MG and MX5 eunos the mx5 came out tops in the first round of tests and continues next month
the magazine is called EVO and the edition is febuary 2009
just shows how good our cars are
 Mick
MX 5 the best car for a grand?
Sounds like a no brainer!  [:D]
You bet.The 5 had only lost 8 BHP in 19 years of use on the rolling road test
 Right.  Pedantic head on, and without being arsed to go get a copy of the mag - was it an MX-5 or a Eunos?
Main reason for asking is that if it was a Eunos, it’s more likely to have aircon than an MX-5 (UK spec if you haven’t worked that out yet) and therefore even more impressive.
as the heading said it is a Eunos and will put a smile on your face if you read the articale
Hi
   Had a chance to read about this at the Fenland Five5 meet, really wished I had now “sorry Stef”.
Hovis: I read the post as a Eunos !
Zippy [:#]
Like I said - pedantic head on, if it’s a Eunos, it’s not, strictly speaking, an MX-5.  It’s a Eunos - roadster meant for the Japanese market.  If it were an MX-5 it would be meant for the UK market and therefore a lower spec.  Title is self contradictory.  It’s either one or the other.
As I said, pedantic.
Sorry
/Pedantic mode
ok point taken just thought it may have been intresting to other members
 You are absolutely right - it is, or at least it should be.  But I’d still like to know (without having to go out and buy a copy of Evo - so I’m a lazy git ok?) whether it was a Eunos or UK spec.
I have to stick up for my 5 here. My UK 1.8i S has ABS, PAS, electric aerial, mirrors, and windows. Scuff plates, cat 2 immobiliser, fog lamp, analogue oil guage etc… (all standard equipment). I’d hardly call it a ‘lower’ spec just because it’s a UK car and doesn’t have aircon and headrest speakers!
I feel there is sometimes a snobbery amongst a small section of Roadster owners who dismiss UK Mark 1’s as being downgraded rust buckets when this simply isn’t true.
I love my UK 5! (don’t forget she was built in the same factory as her brother and sister Roadsters he he)Smile
Cheers
Ben
Well said Ben at the end of the day thay are all 5’s and equaly fun to drive
 No snobbery meant here - I obviously haven’t made myself clear - UK MX-5 didn’t come with aircon in the Mk1s as standard (mostly), and as that is a serious drain on the power output … knowing whether it was a Eunos or MX-5 - and therefore with or without aircon - would have a bearing on the power loss over the years info…
 That’s all.  The differences are subtle but hp is hp right.  No insults intended to any 5 - I love’em too much to do that
Hey Hovis,
Sorry didn’t mean to come across as harsh which i know i did which was unintentional. At the end of the day ALL Mark 1 owner’s, be it Roadster or UK, have to admit we all have a cracking carSmile
I have a dream…a dream where every Mark 1, be it UK, Eunos or Miata, will not be judged by the country it was registered in…but by virtue of it being such a stonkingly great car to driveSmile
Long live the Mark 1 i say!
Cheers
Ben
If you knew me real well you’d know no offence taken - or meant.  And I’m with you…
Looks like I’ll have to buy a copy of Evo…
Wether the Eunos has air conditioning or not surelly dosent really matter in a case like this.
How often do you drive with the air conditioning on?
 I may just buy a copy of EVO then, I hate it normally as it seems to focus on speed more than enjoyment normally and i dont think they are mutually exclusive.
 Im on my 4th 5 now and 3 of them were JDM imported models the other was a 1.8IS 1994 UKDM imported model :wink:
Doesn’t matter whether it’s on or not - the unit gives drag to the belt, and therefore inhibits the power output of the engine - same as having power steering - they’re both on the same belt as well, so just having them on the car will drain the power output of the engine - so yes it does make a differrence.  Folks don’t take the air con units off their cars jjust for the weight savings you know…
OK I take the point and will flog myself with a birch twig.
Why cant you get paragraphs in this forumn- Its not a problem on any of the others I use :slight_smile:
Hey Ivan,
Wouldn’t driving a car other than your Mark 1 be punishment enoughBig Smile
Use HTML to get paragraphs
Cheers
Ben
