If you have one of the bolts out just take it to a good (old fashioned) hardware store or fixture supplier and they should be able to match. The size is determined by the diameter of the threaded portion not the distance across the flats of the head - a 6mm diameter is M6 and the thread will be either coarse or fine. Length probably not that important provided it’s long enough to grab whatever it screws into. If it’s just through a thin dust cover you need a screw (the shank is all threaded) rather than a bolt (part unthreaded and part threaded).
Go to Andrew at Autolinkmx5, he will sort you out with everything you need from a proper enthusiast that runs a Co, (we don’t use any one else for that reason) he will not sell you anything you will not need,just remember one thing …cheaper is not always best, there is a lot of Chinese copy crap out there, and then we will talk you through doing the job, simple as, before your head becomes mush from personal rants, we are here to help the owners like yourself if needed.
