- My model of MX-5 is: MK1
- I’m based near: Exeter
Hi All, Got an interesting issue I don’t see come up often…
My headlights work fine, no issues popping up or down!
But, when I use the manual adjustment red nobs under the Bonet, I can’t adjust them to the same low level, the passenger side light settles quite high which makes me look like I have high beam on!
The driver side light, I can adjust as low as I want to, when I want to adjust the passenger side light, the motor fights back, and won’t let me lower it anymore!
The end result is one light poking up higher than the other, and a car that looks like its had one to many!
The bad point is I get flashed a lot in the dark, and it looks like I have full beam on only on the passenger side though.
I have been taking the 30AMP fuse out so I can manually adjust both with out a fight but I want to sort this properly.
HOW can I adjust the passenger side light with out it fighting back or reseting!
Thanks for any help.
