Having a garage clear out as i sold my 1990 NA so i have the following spares for sale at sensible prices:-
boxed unopened rear axle Superpro bush set,
new pair of standard rear springs,
new boxed pair of Sachs rear dampers.
crank locking tool,
good rear hood cover i.e the cover that goes over it when it is down
wheel nut spanner
new auxiliary drive belt x 2, 1 for aircon, 1 without
set of daisy wheel Eunos plastic center caps - most are missing a lug but still work so free to a good home
Classic Panasonic in car Radio Cassette in working order - removed from a 1990 944 S2
ast
4 October 2020 17:03
2
As per forum rules, a price is required
Hi will you do the rear bush set for 200 posted?
I take it it’s the kit including all rear suspension arms, anti roll bar mounting and drop link bushes?
Hi, interested in crank locking tool, will it fit a Mk1 1994/5 1.8 engine?
Cost inc p&p to Cheshire please.
Apologies if this is duplicate post, got a message saying a moderator had to approve the first. After 6 years of membership!!
Dave
Hi, will the crank locking tool fit a Mk1 1.8 1995?
Total cost inc p&p to Cheshire.
Many thanks.
Dave
Hi
I am in Lymington, Hampshire, SO41
Hi Benji,
I am happy to post for £10 so £210 in total or you can pick them up from Lymington, Hampshire for £200.
The kit contains 3 sealed bags
SPF1991K “R UPPER CTRL ARM INNER & OUTER”
SPF1988K “REAR LOWER CONTROL”
SPF1990K “R LOWER CONTROL ARM OUTER BUSH”
MGRMAN
5 October 2020 17:29
10
Hi Dave,
I am not sure it will fit, i used it on a 1989 1.6,
i remember i had a little bit of an issue with the anchor bolt, almost as if my crank was 180 deg out so had to keep turning the engine over but it worked for me in the end, just make sure you get all the timing marks to align.
I will post for £5
I am interested in the crank locking tool for my 1990 1.6 NA please if no one before me has already taken it. Regards. David
Many thanks, I will give it a go.
PM me how you would like to be paid and I will send my address.
Dave
It won’t fit a 1.8. The 1989 MX5 had the long nose crank which is different. Dave will you please sell it to me when you find out it doesn’t fit please!
Ok Oldfart no problem, not heard back from MGRMAN so if you can contact him be my guest and thanks for the heads up.
Dave
MGRMAN
6 October 2020 09:15
15
Hi Dave,
I will sell to Oldfart then, just thought i would confirm before i send it,
All the best
Hi, yes it would appear to be of more use him than me.
Many thanks
Dave
Thanks Dave, you are a gentleman
Are these still available
new pair of standard rear springs,£30
new boxed pair of Sachs rear dampers.£40
