Hi does the nb use the same gearbox and diff oils as the nc? 75w 90 gl4 2L gearbox and 75w 90 gl5 1L diff? Also engine oil 10w 30 rather than 5w 30? Which antifreeze to please? Thanks
I used 10w 40 semi synthetic in my pre facelift NB which is all it needed much like the NA. Not sure what owners put in their FL versions.
Yes gear and diff oils pretty much the same as the NC, as you say make sure they meet GL4/GL5 respectively, I used Castrol oils.
As for coolant, well I’ll leave that to others, I’ve only used the FL22 stuff in my NC, unsure if it’s the one for earlier models.
Thanks mick
