NC Starter Motor
Reported starter motor problems seem to be common on the MX5 NC and are typically shown up by the starter relay fuse blowing.
The starter solenoid does three things:-
  • Push the starter gear into mesh with the starter ring.
  • Rotate the motor slowly through a separate winding (thereby assisting meshing of the gear).
  • Closes contacts within the starter to connect the battery directly to the starter motor.
A higher than normal current through the starter solenoid part of the circuit could be caused by:
  • Low battery voltage to the solenoid.
  • Stiffness in the gear sliding engagement
  • Stiffness in the rotation of the motor
  • Failure of the insulation (or a short to earth) within the motor secondary winding (i.e. that fed via the solenoid).
  • A short to chassis in the cable between the relay and the motor solenoid.
There are many vehicles on the road with the same Mazda-Ford MZR-L engine fitted to the NC (and some with the same starter motors) but a trawl through their respective Owners Forums did not reveal any particular problems. From Wikipedia they are:-
  • 2002-2012 Mazda6 for Europe
  • 2004-2018 Mazda Premacy/Mazda5
  • 2000-2007 Ford Mondeo
  • 1998-2010 Ford Focus
Looking at the wiring diagrams for some of these the MX5 is the only one with a 20 amp fuse in the starter relay circuit. Ford Mondeo and Focus cars with the MZR-L engine and a similar (1.4kW) starter motor have a dedicated 30 amp fuse in the starter relay circuit. The Mazda 6 (which has the MZR-L engine and an identical starter to the NC) has a 40 amp fuse (although this protects some other circuits as well).
My meter only goes up to 10 amps but I have measured the solenoid resistance at about 0.9 ohms which would indicate 12 - 15 amps at 12 volts. Peak current could higher.
In my case after blowing several 20 amp fuses and not looking forward to changing the starter I inserted a 25 amp fuse and the car has been OK since!
So perhaps the starter motor problems on the NC are due to the 20 amp fuse being a bit too low for the Mazda MX5 – particularly as our cars get a bit older?
