NC1 Rogue Brake warning light
  1. My model of MX-5 is: __NC1 (2006)
  2. I’m based near: __Perth
  3. I’m looking for technical help or recommendations on: __random (!) warning light coming on when i exceed 3k rpm. It flickers on and turns off when revs drop. All of the rest of the car seems to be ok. Any words of wisdom will be gratefully received.
The NC has a warning light when brake fluid in under full. Keep the fluid level at full at all times and the warning light will not come on.
Thanks. I’ll top it up tonight when hopefully and see if it helps/ makes it go away.
