I’m looking for technical help or recommendations on: __bonnet catch
Wondering if anyone knows how to adjust the bonnet catch. Mine seems to sit a little higher than it should at at idle the bonnet latch / catch rattle. I can push the bonnet down and it looks right and the rattle goes away.
iirc… ??? there are 2 x 10mm bolts/nuts that hold the catch ,
mark where the catch sits against the bodywork with a pencil ,then just slightly undo the nuts/bolts and tap down the catch with punch + hammer ( or similar ) until it moves 2mm,
re-tighten bolts/nuts and try bonnet … repeat as necessary .
hth
