The Roadie Invisible Wind Blocker (RIWB) turned up this morning, and before the Hermes courier had left the drive, it was being fitted. Although it is a one-man job, I did have help (or hindrance really).
Inserted the “bungs”, a nice tight fit
I prepared the side sticky bits but kept the protective cover on just in case of scratches
That’s why there are shiny silver mountings at the bottom. Well that’s half the story, the other half is that I tried chemical blackening of them and failed.
. I had that issue on my Mk3.5 with the ILMotorsport one, which was vertical and also suffered from headlight reflections from oncoming cars. This one has a slight tilt so hopefully this will minimise any reflections, time will tell!
