ND RF Factory Options?
Hi folks,
I’m considering buying a ND RF and was wondering what the factory options were, which ones are worth having or are more desirable, also what switches are supposed to be in the lower right of the dashboard? I’ve seen lots with slightly different button locations within the 6 switch pack?
I’m pretty much sold on a Soul Red RF even though I’ve read the paint is pretty soft and should I want anything painted (ducktail boot lid) is going to cost me a arm and a leg.
Anyways thanks for the advise
Have you run through the Configurator already? Depending on what RF trim level you were looking at.
I believe any options presented are dealer fit accessories, so wouldn’t affect the production line build.
I did try but the website wasn’t loading properly, also I was looking at used rather than new - but I guess not much has changed?
This is from an Soft Top Exclusive Line, button translation below the image.
  • i-stop OFF: Disables the automatic engine stop/start system.
  • Speed Warning Off: Disables the ‘ping’ every time you enter a different speed zone or inadvertently drift over a limit.
  • 2 x Traction Control/DSC OFF modes: Deactivates the Dynamic Stability Control or traction control system. One for so called ‘track mode’.
  • Parking Sensors OFF: Turns off the proximity sensors used for parking.
The answer depends what age/budget you’re looking at.
I’m not too concerned about age, more milage - budget is >20k
If you’re set on Soul Red (or the later Crystal version) then with a healthy budget like that you can go low mileage and look for one with minimal stone chips and road rash then have it clear PPF’d to preserve it. As an owner of a Soul Red Sport Recaro, that’s what I would do if I were buying another.
The sixth button that’s blank there is, on some models, to turn the Adaptive Headlights function off.
