- My model of MX-5 is: nc1
- I’m based near: liverpool__
- I’m looking for technical help or recommendations on: _fitting new horns
old horns only have one connection and all new horns have 2 electrical connections
best way to do this please.???
thanks in advance for any help. Mike
One will simply go to earth. Normally marked -
As I understand it, the second connection is to link the two horns together via a length of wire, so the second horn only uses one of the two available connections.
The horns are earthed through the mounting bolt.
The two spade connectors on each horn are both positive and are linked together.
This can be tested by checking for continuity between the two connectors.
This is maybe not quite as straight forward as it may seem then. Some do indeed have 2 + terminals, some have one & some have a +ve and -ve.
Just checked a pair of new Stebel horns I have and they definitely have continuity between the two terminals
Unused Stebel TM80 snail horns for sale
Buy and Sell [Replies by PM System Only]MX-5 & Roadster Parts For Sale
13 May - Please use the Personal Message (PM) system to contact me. Pair of red unused Stebel 112 db snail horns for sale, still in box complete with relay. £25.00 posted. 20210513_135954 20210513_140006 20210513_170737
Thanks folks for quick replies
Mike.
