So after doing “little bits” on my cars over the years I have wanted a bit more of an in-depth project to help me learn. I’ve wanted an MX5 project for a long time and have found a really cheap one and I’m after some advice about it, mainly to see if you guys with experience would think this project would be too much for a first timer.
So it’s a 2001 black 1.6 icon, 5 speed, 90k miles, not too sure on history yet, there is rust on one of the rear arches but supposedly it’s solid everywhere else.
It is a rolling shell, literally everything has been stripped from the car. The guy has said that this was going to be used as a project to fit a V8 into but no longer has the time and is selling everything. So it’s a stripped 1.6 which comes with everything ready to go back on: engine, gearbox, dif, all interior, running gear, soft top, exterior etc. Literally everything.
So my plan would be either put it all back together as is as a “mini” project and in the future fit a turbo kit, intercooler, clutch, management system, LSD, probably keep the 5 speed (would consider changing to 6 if possible), better brakes, suspension, wheels, exhaust, roll bars and then the cosmetics. Or, find a 1.8 engine and first start by fitting the 1.8 , 6 speed gearbox, LSD and whatever else needs doing and then in the future again, look at adding the turbo and all the other bits mentioned above.
So I’m trying to figure out is what I’m asking of myself too much as a first project? Are the MK2 MK5’s a good/easy car to work on? What would be my best option for the project out of the ones I have mentioned? I do have some mechanical experience and do enjoy a challenge.
Any advice is much appreciated.
