- My model of MX-5 is: 1989 1.6L
- I’m based near: Luton
- I’m looking for technical help or recommendations on: what all should I do first
So I bought the car from fb marketplace on 30/05/2026 from Norwich and drove it all the way to Luton.
So now I’m home I want to take care of all that needs to be done as this car doesn’t have a lot of history in in paperwork
Only what the seller told me
Ie; battery was changed on the 14/04/2026
Timing belt was done two year ago (no receipt hence I don’t have a proof other than her words)
Last service was done on 02/06/2025 at 189518km. Things done:
engine oil
oil filter
air filter
fuel filter
pollen filter
spark plug
rear brake caliper
rear discs pads
For this I do have the receipt and that’s the only history I have, and when I checked I did see the power steering belt has been replaced recently as it looks new.
Ride back to Luton:
When driving it there was a squealing sound coming from the engine bay I wasn’t sure what that was at first but I seems like to be the alternator belt. It seems to comes and goes after a certain rpm.
Oil is pretty black and previous owner was using 5w40.
Coolant pipes are brittle and radiator has seen better days
Handbrake needed to be adjusted
Plan forward is as follows:
Engine
- Engine flush using Amsoil engine flush,
- Using 10w40 semi synthetic oil
- Motul 4100 SYN-nergy 10w-40 Engine Oil 5L
- K&N Performance Oil Filter
- Gates V alternator belt
Cooling
- New radiator from Bofi
- Silicone hoses set
- High flow fans if needed
Gearbox
- Gearbox flush Amsoil
- Amsoil 75w90 GL4 oil change
Differential
- Idk if I can flush is with the same from Amsoil
- Amsoil 75w90 GL5
Then address the sill rust on the side that’s not been done( I would give this to a professional)
Rest I plan to do it myself
Let me know if I need to change anything or add anything more to the To - Do List I would really appreciate that.
I might consider adding new iridium spark plugs and sparks leads along the way
Thanks you all for their time and going through my list. All and any insights are welcome, again thanks a lot
