Much as I would like to say get tyres first and get “these,” it will be pointless having more grip without the suspension to cope with it. I expect the car already rolls considerably.
I would talk to someone who supplies Meister suspension first, or talk directly to Jerick Lo who you will find on Facebook.
Next up, if you have more grip you will likely need better brake pads. I am aware Yellow Stuff are popular and that EBC have recently done a series of videos promoting the product however personal racing experience would say they are not optimal! If you want to stay EBC I would go for Blue.
5.1 fluid again is more to do with ABS systems and while it has a high boiling point it is more compressible and absorbs water quicker than 4 fluids, of which there are a number of very good high temperature products.
Thanks, will look into the Meisters.
What advantages would I see from the blue over yellow? I found that the yellows performed brilliantly, my first track day (which was cut short due to my car blowing an engine) I had standard pads and they couldn’t last a lap. Whereas my next track day (new engine and all) I had the yellow stuffs and felt like I could just keep on going. How would blues improve on this?
In addition. Just an observation and opinion.
Dot 4 and Dot 5.1 brake fluids are glycol based and will therefore absorb moisture over a period of time. Hence, why they recommend you change the fluid as per the manufacturers recommended period.
My opinion would be, they would “probably” do so at a very similar rate like for like.
Dot5.1 does have a higher boiling point as you know and is not just specific for ABS systems.
DOT 5 is silicon based and does not absorb moisture content.
Suitability would need more research for a specific system etc etc.
Used on the much newer modern cars.
Glycol and silicon fluids are not compatible.
Enjoy your racing it’s fun!
