Hi, I was rather heavy handed in turning the heater control of my 98 MK2 to maximum and since then the heater does not supply any heat whatsoever. Any ideas on what I need to do would be very much appreciated. Rob.
Most likely the cable has become detached from the slider, you will need to remove the centre console and Hvac unit to reattach it
Thanks very much.
This might work if the controls are similar to MK1. Take off the plastic trim below the steering wheel, get your head inside and look to your left . (you will need a light to see what your doing)
To your left there is a white box containing the heater control thingy’s and you should see a wire that should hook over a round plastic clip thing> wiggle your heater control to see the wire, it might have just come off?? This might work have a look and see!!!
