Not sure of the brand of the pattern radiator I put in that came from Autolink. It looked the same, however, the drain plug was completely different, ie you cannot fit a replacement Mazda drain plug to it. Both designs are a terrible plastic design that chews up. Also, before fitting, I took the precaution of giving it a flush with water, and out came loads of aluminium dust. Maybe all aluminium radiators are the same; a few years earlier, I had a 91 which overheated due to the thermostat bypass hose being blocked with bits of aluminium. Conventional wisdom is this is swarf from when the cylinder heads were made.
