Hope anyone can help ,my G reg 1.6 was lumpy in 1st and 2nd this morning, then at lunch it would not start for toffee, cleaned the plugs and the well closest to the fire wall had a lot of oil in it :( It would start but was lumpy and then stallso after recovering the car home I reckon its the valve cover gasket.
I would normally attemp this myself (reason for buying older car)but unfortunatley my arthritus is flaring up at the moment so a couple of questions
Roughly how much for a garage to do this?
2.Is there anything else I should get done at the same time CAS O ring for example
Iy will be the rocker cover gasket, they are about 10-15 quid half an hours labour max. The CAS seal takes about the same time but costs about 3 quid.
Only use genuine Mazda replacements as the aftermarket ones tend to be quite hard so don’t seal properly. Swap your plugs at the same time, I would think it’s tracking causing most of the problems.
Right I’ve replaced Plugs, leads,coil.crank angle sensor + O ring,airflow box,airflow sensor,new filter and gaskets and O rings, car starts misfires and then the revs drop off, is this the base idle thing or am I barking up the worng path? I’ve just ordered manual and diagnostic tool thinggy so hopefully that will help me a bit.
