Sorry, meant to ask, regarding the G3, is it best to use the liquid or the paste, have looked on-line but they don’t mention this, is one for use with
a machine?
a machine?
I get on better with the liquid as the paste dries out a bit quick while working it for me.Flicking a bit of water onto your pannel while rubbing helps sometimes. I buy it by the larger bottle for work but you can get the handy smaller tubes. It will leave very fine swirls so you will need a cream to take those away and give you the final shine before waxing. Good luck
Thanks Nedski - the fine compound i have (from old) is more of a paste than a liquid, and as you say,
it does dry out fairly quick when in use, i normally use it on a damp cloth but will dump all my old
habits and will now go for the G3 liquid and use waffle pads. I have a bottle of Meguiars cleaner/polish
which i guess will do as the second stage before the final carnauba waxing. Thanks again for your help
and suggestions. Regards Reg.
