I can not get my eunos to start, I have tried to jump start it to no avail. I have the jump leads conected but it will not put any juice into it. Any ideas? I have just put it on charge. Now I wish I had taken it to Holland with me
Have you checked the main fuse?
I just checked the main fuse and that is fine, I have not driven the car for 2 weeks.
Mine did something similar. If its not sealed then check to see if it needs topping up with distiller water (mine did) then put it on charge if you have access to a charger.
Do you get any dash lights ?
Could this be the dreaded sticking starter/solenoid ?
Or possibly the ignition switch has no contact on the ‘‘start’’ position.
I just realised what the problem is and its me I forgot to disable the immobiliser
I can not believe I forgot to do it and just to be even more nuts I tried to jump start it and then I put it on charge and then I posted on here for help. Oh my god I have never been so stupid in my life. My girlfriend is pissing herself with laughter. Oh dear I do not know how I could forget.
On a positive : you know it works .
