I took my wife’s Kia Picanto shopping trolly in to have the O/S DRL bulb replaced (cant be bothered to remove the wheel & arch liner myself)
Job was done £23 including bulb, fine.
“Oh by the way your front pads are on the metal & you need new discs; £200”
Maybe this should have gone in the daily jokes section
This car has done 13000miles in 5 years & the discs are good. The pads still have meat on them so when I get round to doing it I can source Mintex pads &2new discs for about£65.
I always use a local small GOOD garage but needed the light doing quickly before a trip to Wales in the Kia shopping trolley. Can’t take the 5 because we are visiting grand children & need 4 seats!!! Don’t see why the children cant take a bus; they are 6 & 7 after all
Halfords talked my daughter into having an MOT test, it had 6 months before it expired, she had it done.
Surprise, surprise she needed the front brake pads replacing and a new tyre as it had a object embedded in it that surprise again couldn’t be repaired…
I bought the car for her 12 months earlier and it had fitted new discs and pads to the fronts then. Seething i certainly was but she let herself in for this, telling me after the work was done.
My local Kwik Fit is great. I had occasion of a stuck oil filter, and had to slink off to Kwik Fit of a filter and oil change. They didn’t have a filter in stock, and couldn’t fit the filter I had. So, on a busy saturday, they said go ahead use their ramps, feel free to borrow the filter extraction tools they had. Got in there, and the lads turned around, and said don’t worry, we’ll do it for you, FOC. Feeling guilty, I said can I at least buy some oil off you. Whereupon they told me to save my money, use the Unipart semisynthetic I had in the boot. They did it all, no charge at all.
My issues with garages have always been the independents, where they have verged on criminally incompetent:
Forgetting to put water back in the rad after a cambelt change
Leaving hub nut finger tight after bearing change
MX5 specialist being utterly convinced that low oil pressure readings was due to faulty water thermister
Said same specialist thinking a sill repair would be a rub down with sandpaper and rattle can it
Independent garage putting directional tyres on back to front
Took a wheel with a tyre that was half worn for a puncture repair. Small nail in the centre of the tread. Operative looked at it and said he could repair it in an hour s time. Returned an hour and a bit later to be told the Manager said that they would not repair it as it was too worn. Took it to a local guy and was done within 15 minutes.
