Looking for a replacement length of rubber power steering hose, approx 160mm long, 9mm inner diameter, 18mm outer diameter.
Anyone know of a supplier? Struggling to find anyone with it.
Go to any local to yourself hydraulics hose supplier, there are many many about usually on industrial estates, Pirtek as an example although i personally wouldn’t use them as they tend to be expensive and are no worse or better than others.
If you are local to me i’ve almost definitely got some on my van.
If it’s a drop hose from the reservoir it’s not under pressure so any heat resistant hose with that I/d will do
