I bought a NC 3.5 PRHT from EMG Mazda a couple of years ago, and it has been serviced by them since. However the King’s Lynn branch is no longer a Mazda service centre, so I was wondering if anyone can suggest somewhere else locally?
Thanks.
Donald’s of Peterborough are the nearest Mazda Dealership
I used Fast Eddie at Coltishall for a big service ( Give the car a good once over, pre MOT insp and replaced ‘All’ fluids) , he also noted a flat spot, cured when he fitted the correct spec spark plugs !
I had the actual MOT and 4 corner Wheel alignment done by https://autotest.org.uk/ near the Airport.
Thanks for both suggestions.
