Simple,cheap, Protection cap for aerial socket.
Hi Gales - that will definitely work:-)
If you look at the fixed mast base of these aerials, early and late type, they are all fully sealed or at least they should be if the sealing washer is in place. The exposed metal when you removed the mast is non ferrous with a blind hole. To stop rain filling that hole, you would only require a suitable bolt or similar to plug the hole left by the aerial mast.
