This is my Cort Action Plus full scale 4 string bass. It is in excellent condition being very little used, bought during lockdowns.
Achieved some 12 bar blues then and been under the bed in it’s case since.
It comes with a Gator hard case, set of unused flatwound strings, guitar stand, bass Tab White book, bass tuition book, lead and plectrum.
The following details are from Absolute Music where this bass(just the guitar) is now £219 new, so grab a bargain.
Action Bass Plus features PJ pickup set, P-type bass pickup is ideal for genres such as hard rock, classic rock while the J-type pickup is well-suited for jazz and pop. This combination provides a wealth of classic bass sounds for virtually any musical genre and style.
Laid out in Volume, Tone, Bass and Treble configuration, the 2-band EQ provides boost and cut functions for carefully selected bass and treble frequencies. This results in wider tonal range with a firm and focused low-end with a smooth usable boost.
Found only on the Action Series basses, the ergonomic body shape, which fuses the best elements of classic and modern designs, was designed to reduce fatigue and enhance playability for extended playing sessions.
Precisely manufactured for the utmost in tuning stability and functionality, Cort’s die-cast tuners assure that you can play each note with confidence and authority.
Specifications
CONSTRUCTION: Bolt-On
CUTAWAY: Double Cutaway
BODY: Poplar
NECK: Canadian Hard Maple
FRETBOARD: Jatoba (400mm(15.75") Radius)
FRETS: 24
SCALE: 864mm (34")
INLAY: White Dots
TUNERS: Die-cast Tuners
BRIDGE: EB6(4) Bridge
PICKUPS: PSEB4-4/F & PSEB1-4/R Pickups
ELECTRONICS: 2 Band Active EQ
HARDWARE: Chrome Hardware
£175
