stick on number plate
A few photos of my MX5 now with a stick on front number plate and square rear number plate.
Lee
hi bodie, looks very nice, was there much to do, getting rid of the original no plate fixing holes, or did you just stick over them, also was it hard to stretch your new number over the curves, and still keep an even straight line.
regards  leemarb
 Hi Leemarb,
I stuck it over the original holes, can’t even tell they were there. Going over the curves of the bumper is a nightmare, will need to order another one at some point to have another go but for the minute it’s not bad! I think it makes the front end look fresher
Bodie
Is the front one road legal?
Technically no they are not legal, but ought to be really unlike plastic plates and plinths which break and fall off very easily these are a lot more permanent. I have stick-ons on both our Eunos Roadster and Mk1 and both are fine as far as two separate MOT stations are concerned. Police all over the country dont seem too bothered either…
Am going to add that I firmly believe the main reason for making people have upright BSAU approved front plates is to make it easier for speeding tax sneaky camera vans to read them at longer distances, so good enough reason on its own to have a stick-on.
I have also noticed with a few speed limit reminder electronic boards around here that they notice Mk1s a lot easier and sooner if the headlamps are up (radar reflection again…)
Dr. EunosGeek
Yes, definitely a market for a radar absorbing paint finish and a low radar signature shape nose!
They’re sort of legal on pre-2001 cars.  Technically I don’t think you’re supposed to fit a sticky plate now, but a pre-existing sticky plate - and no-one can tell when it was first put there -was “tolerated” under the law.
On a post-2001 car it’s definitely wrong as the plate must meet British Standard, and it won’t.  You’d probably never get pulled up on it though, as the MoT only checks spacing and condition, not the type of plate.
Both my MOT men have said, as long as they can read it from the MOT bay when its outside waiting to come in then its a passWink
Just for you, have a giggle at this old chesnut Wink
 I did mine a little differently  (if the picture appears  ! )
        Try again ! !
I like where you’ve put your plateThumbs up, was thinking about mine there but went for lower down in the end (What a pain to fit)
Bodie
 I know what you mean about trying to stick it around the curves. Thats why I went for moving the badge up onto the bonnet and re sticking it on with silicon sealant. My plate went on without any issues using water and a bit of baby shampoo to allow it to slip into position. I think the plate position gives it a more classic look without drawing too much attention from law enforcers.
I’ve got a stick on and not had any issues from plod or the MOT.  I just like the E-type look!
Heres an E-Type look I prepared earlier…
Just spent most of the day converting the USA spec E-Type V12 5.3 to right-hand drive, a task not for the faint-heartedShock
Dr. EunosGeek
Mmmm to that E-type.  What’s the nearest thing to an E-type that is on sale today?
Here’s the position of my stick on plate:
Mine passed its MOT just a few weeks ago. If this is illegal then so is every E-Type I’ve ever seen!!
 Lee
front stick on plate looks great, can I ask where did you get it from, and was it hard to fit, I was worried about fitting it with the curves on getting it all smooth, but what you have done lookks just the job
Andrew
 Plenty of companys on ebay do them ready made and properly spaced, in legal text (Charles Wright text I believe). If you mix a little baby shampoo in water and smear it on the front of the car, this allows you to slide the peeled  number plate about . Then, when yo are happy with the position, squeegy out all surplus water from under the number plate. It doesn’t affect the stickyness of the number plate which dries and then remains in place.
