Hello guys ive noticed a strange fluid running from under the what i think is the carbon collector there are no obvious leaks from any pipes etc its no corrosive and is clear like brake fluid but its not that
has anyone any idea what this might be?
If you have A/C could be water. Could also be rain water draining out many of the holes in the underbody
Hi Thanks for the reply i dont have air con and it a fluid like oil of some kind not water
Mine still leaks Dinitrol ML. Check brake and clutch fluid levels
Hi yes ive had a brake fluid leak from rear caliper that has been replaced i will keep an eye on the levels thanks
