Style bars fitting
Purchased a style bar that fits under the Seat belt bolts on the tower at the top, seem to be having trouble relocating the long bolts back in, is there a trick to it or am i doing something silly[:@]
any help you can give will be appreciated
Chris
 Not sure if all models are the same but I didn’t have any problems refitting mine recently, on my Mk 1
i had issues with mine i found if i loosened the other one off a bit it went in fine
 Funny enough I had exactley that problem at the weekend when fitting Donnas style bar on a 2.5, until i realised i needed to remove the loose washers under the plastic fascia.
 But obviously different bars have different mounting styles, but check that if i were you.
