Hello All,
Thanks for all the replies.
There is overlap between the various systems. As I understand it, TCS does apply the brakes. I don’t think that ABS operation has much to do with this particular traction problem. I am not aware of ABS ever having operated on this car. I drive very carefully nowadays.
I am slightly relieved to find out that a typical TCS can be caught out by the uphill slope situation. I hadn’t known thhat.
To reply to one of the many comments, I am not 100% sure that I really have lost traction when this problem kicks in. On a slightly slippery road - maybe a little. In an underground car pack with on a good surface, I’m not so sure.
To reply to another comment - I always use winter tyres in winter.
I am of the view that the algorithm that decides that traction is lost and that action needs to be taken is over-enthusiatic. I think I know how it got fooled on one or possibly two occassions but otherwise not.
On the first time, I was driving up a long slope from an underground car park and a pedestrian decided to walk down the ramp. I de-clutched and applied left and then right lock to roll backwards and tuck the car into the side of the ramp to allow the pedestrian to pass. I could not hill start from this position.
The other time, I was driving up a very steep and very tight spiral ramp from another underground car-park, I had to apply a lot of steering input to avoid the walls. This was particulalry scary owing to lack of space and that other cars had followed me up the spiral and the drivers were getting very impatient (indeed) as I got slower, slower and slower. I was on the point of rolling back into the car behind when the slope levelled out and things seemed to return to normal.
On all the other occassions, I have no idea why things went wrong. Maybe a very slight loss of traction that would otherwise not have been an issue or perhaps even noticeable.
The car is going in to have the door locking and engine start electronics and sensors changed again (second or third time) next week, I just wondered if there was anything I could tell the dealer to look out for with this TCS problem.
I am going to put a label on the dashboard to remind me to turn TCS off everytime I get into the car. That is probably going to be the best solution.
Thanks for all the useful and informative replies.
Regards,
Paul.
