Torsen "Limited Slip"
After being howled down over my criticism of the so called (Torsen) limited slip diff. and moving on to a clutch type locking diff, how is yours performing in the snow? [:(]
Now you know how mine felt in the wet. [:O]
 I’ve replied to your other Torsen thread.
They’re useless in snow & ice - but I wouldn’t change it.
Useless in the wet too! One wheel spinning with all the power is really nbg.
 Are they that bad in the snow?  I thought Torsens only allowed one wheel to spin up if it was off the ground, i.e. no resistance at all.
I get one wheel spinning in the wet all the time if I don’t take care. I suspect that it would spin one wheel in the wet up to 100 mph in 4th gear (if we were allowed to do that kind of speed).
 I tried the handbrake trick and I certainly found it easier to get a grip on my icy driveway this morning.
Also in here … http://en.wikipedia.org/wiki/Torsen
Boris, what tyres do you have on the car? When I first got my car it had cheap hedge finders on the back, I experience power oversteer at 85mph on a curved stretch of autobahn, which was ‘interesting’!
Saying that the Goodyear F1’s I currently have fitted struggled on frozen compacted snow, with one wheel just spinning up uselessly. I’ve put a 32kg battery from work in the boot, which seems to give the car enough grip to make progress.
This is bizarre for me. I’ve just bought a Mk2 1.8S (which will have an LSD). I had no problem driving along my snowy road tonight, even though it’s very slippery. So that’s fine.
The bizarre thing is my old '92 Eunos 1.6 got stuck on a road today… and the problem was that one wheel was spinning and the other wasn’t moving at all.
Does that mean my Eunos has a LSD? I have to say if that’s cast-iron evidence that it has, I’ve certainly enjoyed the handling of the car in the wet and snow :slight_smile: And today has been the only time it’s got stuck, except the other big snowstorm a few years ago, but that was on a steep hill.
 It will have a VLSD (viscous unit) and these lose their effect after about 60,000 miles.
I’ve seen this stated many times; I thinks its largely apocryphal. Certainly, my vlsd seemed perfectly functional after 140k miles. Superb write-up by Lance Schall over on miataforum.com;
The lifetime of the vlsd seems to be variable; from forever to 30 minutes, depending if the car is hammered or not. Most are driven normally, so the vlsd should be in good shape (though there were a spate of diff failures on very low |Roadsters; the diff housing getting cracked, an entirely different issue).
