Give everything a good service. Special attention to the brakes, some circuits are very hard in brakes.
Make sure the discs and pads have plenty of meat on them.
Also worth changing your brake fluid for a Motorsport spec one to stop it boiling after heavy braking, as you’ll lose brakes.
Plenty of tread on your tyres also, and watch the pressures after a few laps, you will have to let air out as they get hot and expand.
That is not particularly the case. You need guage of rubber to generate heat in the rubber to energise it and also to confirm to the features in the road. It is a balancing act between too much tread and overheating, and not enough to be effective.
