Just done a full fluids service on my ‘new to me’ 2010 NC only to find that some monkey in the past chose not to replace 2 of the protection plates from under the gearbox. The first one located directly under the bell housing, the second one under the rear of the gearbox.
Would anyone know how critical these are likely to be ?? Can I get replacements ??
Cars didn’t have covers until fairly recently, (well it feels recent!) So you’ll be fine from a damaging the car point of view. They mainly keep the underside of the running gear clean afaik. Mine doesn’t have the rear cover from the pics, and the front one is a different shape too
I tend to agree with BBB.
But, bearing in mind their weight saving philosophy, Mazda clearly thought they helped in some way.
So, it is plastic under radiator, tin under the engine, plastic under the bell housing, tin under the gearbox
the one under the engine is metal on mine with deadening material. Its really rather heavy for something with little purpose. I’ve lightened it a tad by losing one of the 5 bolts that hold it on. I’m sure it will turn up when I get another car
I queried this some time ago here as my car (NC1) has only the plate under the engine. I was concerned the others were missing as the chassis has all the tapped holes for them. From the replies of various owners it seemed the engine plate is always fitted but it seems to be (almost) random as to which of the others are fitted.
JS
I changed gearbox oil on an NC2 once, it was a 5 speed. Surprised to find that ali cranked cover missing covering the gearbox. Maybe they didn’t fit them on the 5 speed or some NC2’s onwards?
