Finally thinking it may be time to reduce the body roll on my car and would like to get hold of some better ARBs - what’s out there?
I am using RX8 yellow dot bars
Change the drop links at the same time. You will probably have to as it’s usually a pig to get them off without resorting to an angle grinder.
This is good advice changed all mine when installing the new ARB’s. A set of aftermarket ones (x4) was only around £40.
I can echo all that said above…
I looked on Facebook market place for people breaking RX8’s I got a set of Yellow dots for £40.
Make sure you get the brackets as well,
I think the brackets are the same but the bush id is different due to the thicker bars. New bushes are cheap in rubber or you could go to poly if you feel it necessary.
There’s a yellow dot RX8 set on tonight for 55 nicker…
