Warning lights
Hi.All
I have a 1992, 1.6 Eunos. Manual.
 I have just changed the rad & all was OK there,  took it out on a test drive & all still OK. The next time i took it out (a week later) starting it from cold, the battery charge & the heat warning lights stopped on. Took it for a 10 mile run & all seemed to be OK, re started OK,  battery seems to be charging, fan belt tight. checked to see if i had pulled any plugs apart
Any ideas?
Cheers Phil
belt slip / bad contacts on alternator ;)
was the altanator causing the problem. when i got back from an evening run the batery was flat
