Please help. Recently I noticed a lot of condensation on the insides of the windows. After lifting the Mats I found a wet patch in the drivers side footwell. I’ve dried it out and tried a hose to spot any leaks. No Joy!!! The tray in front of the windscreen seems to drain fine & the roof seems ok. Has anyone experienced the same problem on the drivers side and if so, any idea how to stop it. It has only started doing this over the last couple of weeks??? Thanks Paul.
Paul
Blocked drain tube behind the seatbelt towers, have a look in the garage section. With a blocked drain tube the sill will fill with water and slosh everywhere…
I’ll see if I can find the link…
Thanks Tim. Because the problems at the front, I didn’t think about the Sill drains. Had some welding done at the bottom of the rear wing, proberly no drain holes left. I’ll drill them out at the weekend. Thanks again
No Luck. Cleared out the hood drains & opened up the sill drains. Just been out to check and the carpet is wet again. Anyone have any other thoughts. Could it be coming from somewhere at the front???
