Hi, what is the correct or nearest match to the original wheel paint for a MK2.5? Thanks in advance.
Just about any silver metallic paint.
I have used Halfords Ford Starlight Silver on my 16 inch “Sport” Wheels and that seems to match quite well, but if you are touching up more than a small scuff on the edge of a rim you should try to spray a complete spoke and “feather in” at the rim and hub.
Hi Sunlight, thanks for that I shall try it, did you lacquer it? I have a MK2.5 with standard wheels.
Thanks for your advice.
Regards Dave
Yes, it needs the lacquer to achieve the gloss level, and to protect the paint.
