Hi
I am looking at changing the fluids in my mk2.5 sport mx5 on friday but need to get the oils for the job
The ones i want to do friday are (if i can remove all the plates from under the car )
6 speed gearbox and diff …
I dont know if its a lsd on the sport or not ??
Any one help with best stuff to put in ? and how much to buy !!
Thanks shane
Suspect this is all in the faq somewhere, but always ready to help out a fellow 6 speed owner:
Gearbox 2 Litre oil (API GL-4 or GL5 SAE 75w90) Sump Plug Washer, Mk1 for Gearbox drain(GBox filler is tapered plug and doesn’t need one) Filler: 24mm 27-48Nm Drain: 24mm 27-48Nm
Diff 1 Litre oil (API GL-4 or GL5 SAE 90 or same as gearbox, many people swear by Redline MTL 70W-80) Filler: 23mm 39-54 Nm Drain: 24mm 39-54 Nm
Alan1
10 April 2009 11:22
4
I found castrol web a good source of imformation www.castrol.oil.co.uk put in your car and stuff and it will advise what castrol oils tom use, I as you have guessed use castrol - magnitec etc for my car
