The steering on my 2.5 (right hand drive) started making a funny noise the other day, sounded like the power steering pump was having issues. Checked reservoir, bone dry. Topped it up (it really doesn’t hold a lot does it!).
Gave the pipes I could see a quick once over just in case I could spot anything obvious. I was originally intending to top it up and then see how it fared and only search for leaks if I definitely knew there were any.
Pipes are a bit tatty anyway and are mostly hidden behind stuff so wasn’t too hopeful however in plain sigh there was a blister (for lack of a better word), I cleaned it up before running the engine again and then tested it after. When a tissue is pressed against it it comes away with red fluid on it (same colour as the steering fluid). I know absolutely nothing about the power steering system but am assuming that as the fluid is only weeping out it must be a return pipe of some kind right?
Looking around online and at a bunch of different parts retailers there seems to be quite a few different individual pipes in the system but I can’t find a picture or description of exactly which pipe is which.
By my reckoning, I need this one here but that’s as much a guess as anything else.
This is a picture I took earlier. The one that leaks is the middle, darker one.
Here’s a close up of the leak if any one’s interested.
Can anyone help me definitively work out which pipe is which?
Also, how big of a job is this to replace? I would prefer to order the parts and replace them myself but I’m essentially just an amateur with a tool box, I don’t have access to lifts or pits or anything.
Are the unions likely to come undone or are will they probably all be rusted in place necessitating the replacement of other parts too?
Should I spend the extra money and replace the other two pipes whilst I’m at it?
Any help would be appreciated, thanks
