wiring up heated rear window
Hi all, my mk1 has a glass rear window wich is heated, hav some wires and a plug on n/s, but dont hav a switch!. wot i need is some one to recommend a good person/place or a site with a sep by step guide WITH pics, cos i dont do lectrics Cambridge area is best for me thanx goochie
You need a Mazda switch - the back of it is blue, plug in the blue connector behind the blanking panel
 also a relay, the socket is in the boot, behind the trim, inboard from the number plate
also a fusebox that plugs in by the aerial (unless you have an electric aerial, and it is the same fusebox)
and lastly the loom
All available at mx5parts
Richardn thanx for the reply think i may give ity a try looks like its self explanatory once hav all the parts in my hand cheers for the pics and info Goochie
