Would a mk1 (1.6) cam cover fit on a mk2 (1.6)
As the title really, as my 5 is in daily use i could use a spare cam cover for polishing purposes and the mk1 cam covers for sale are more plentiful, Ta! in advance.
 The MK2 has the cam sensor mounted though a machined hole on the front of the cam cover whereas the MK1 doesn’t. So it’s not a straight swap. Also the coil pack mounting points changed though the years. You may be OK with a later on in respect to the coil pack but not the cam sensor.
Thanks for the reply, think i’ll stick to sourcing a mk2 1.6, at least i know now - cheers!
Out of interest, would you be interested in renting one off the club?
