Hi there,
I’ve just acquired a ‘94RS. Don’t know much about them. Any info will be appreaciated such as what the main differences are and what is or isn’t missing from the original fit.
Cheers,
Pete.
There is some info here, in case you’ve not already seen it:
http://www.goodwoodsportscars.co.uk/section783453.html
Pictures will illustrate the visual cues:
M8 Montego Blue
Power Mirrors
15" BBS
Yellow front Strut
Kevlar Recaros
Nardi steering wheel with rubber crash pad
Single RS decal on front wing
BBS Shocks, matched track road ends, thicker front ARB, “lighter” flywheel, Type Torsen, 4300 final drive.
Also Nardi leather gear knob…
I have a pair of RS Ltd
Both missing the Recaros , one is as standard apart from seats.
The other is fitted with a Cammed High compression engine with Bike ITB set up. The interior is out off and R Ltd ( its Red )
If you need any onfo I might be able to help.
