My sons 2.0 nc failed the emissions on the Mot today the car does not smoke drives great uses little oil so shocked at outcome mot tester said it needs new engine car has done 125k mileage drives with no rattles or issues i need a pointer where i go from here i did notice on the readout that the engine size was wrong its had a recent oil and filter change and a fuel additive added to the fuel still believed to be in the tank as he only drives local i would be grateful of any pointers
If the engine size on the Print out was incorrect It would surely make the print out Null and Void and as such so would the fail be Wrong Would it not???
Result from mot
Fast idle
rpm 2398 pass co 1.812 fail hc 361 fail lambda 0.932 fail
second fast idle
rpm 2468 pass co 2.189 fail hc 365 fail lambda 0.921 fail
natural idle test
rpm 728 pass co 0.489 pass
The likelihood of it needing a new engine because of exhaust emissions failure is slim to zero.
The exhaust emissions (before they become emissions) are controlled internally by the ECU, in the petrol/air ratio.
When they’re burnt, then they become emissions, they’re controlled by the catalytic converters in the exhaust.
Sounds like a cat failure.
