I have two 15" wheels (15x7, correct 54mm bore, 35mm offset, 6.8kg weight) in the Minilite style from Swiss supplier Maxilite. These have a dull silver finish, with diamond cut lip. The spoke style is similar to that used by Watanabe.
Almost as new; they have scratches on the mating face from skimming a 1.8 front caliper. Maxilite had obtained TUV certification based on 1.6 brakes. To fit to a car with 1.8 calipers, 5mm shims are needed, or the calipers need to be ground a bit.
The wheels have never been on the road, and would be suitable for drift wheels. They had been fitted with tyres previously, and so have valves and weights fitted. Push fit traditional style centre caps.
New cost is 155 Euros per wheel plus shipping:
https://shop-eu.maxilite.ch/Minilite-Style-7x15_3
I would like £100 for the pair, collection only from LU7.
