Hi folks.
i have an 06 NC 2.0 with the optional Mazda speed body kit.
Discovered that the fog light were burning through fuses and one of the lamps need replacing as its corroded inside and falling to bits.
So off it comes and I quickly realise it’s nothing like the fog lights I can order from mx5parts.
Has anyone got any idea what this is?
Not original Mazda parts? Branded as Hella.
tried googling the codes on it to no avail.
I take it you’ve tried the Hella catalogue website, or asked Hella if that model has been discontinued, is there a replacement?
Search for Hella UK and get their phone number.
Phone them up and advise them on the numbers on the lamp.
They pay well be able to advise you where you can buy the lamp units.
Hi both, already dropped hella uk an email, will see what they say ??.
I was hoping someone here might randomly know as there’s a huge collective knowledge.
Thanks for your input.
Hi
i know what the name of that particular range is if it helps
they were called Micro DE
i had a set years ago
it may get you a bit closer searching ![]()
Example below ,
https://www.rallylights.com/micro-de-premium-fog-lamp.html
After the pointers in the right direction and some eastern european sites visited, i’m pretty sure the PN is 1NL 008 090-091
https://www.amazon.co.uk/HELLA-1NL-008-090-091-Halogen/dp/B00H8QJ4XI
confident I can track them down now.
Thanks Paul20v.
