- My model of MX-5 is: 2007 NC 2.0 Sport
- I’m based near: Blackpool
I have completed a test modification to install real coolant temperature and oil pressure gauges together with coolant overheat and low oil pressure warning lights. I also now have a radiator fan running indicator light.
After doing this and checking coolant temp readings with an OBD I can honestly say the standard “pretend” gauges are pants and probably cause more problems than they cure.
My coolant temperature changes up and down above 80 degrees more than the factory gauge shows and the factory gauge gets nowhere near the top quadrant when the fan kicks in at 100 degrees, it pretty much stays in the middle once running temp is reached.
My oil pressure fluctuates nowhere near as much as the factory gauge indicates.
There are no proper scales on the the factory gauges and so they just do not give us any decent information or warning of impending doom. Even if you do not want to go down the real gauge route I would definitely recommend warning lights for low oil pressure and high coolant temperature.
I am guessing this is why we hear stories of “weaknesses” in our engines when they fail through overheating or low oil pressure. We simply do not have proper warning that something is going wrong.
Why oh why would Mazda compromise the car like this?
Don’t get me wrong, I still love the car and now actually drive it a bit harder and with more frivolity than before
. Just wanted to get this out there.
