2016 MX-5 Weak screen wash flow
Best price for a washer pump
Have you flushed out the pipes to the screen nozzles. I just had a trickle from one, turned out the pipe was sludged up.
Stick the pipes in the next COOL WASH cycle,
Cool only,
Did you have to take the plastic cover off for access .?
Yes but this was on my NC, I would think it’s similar on the ND, cover off.
:+1:
No I tried a new pump but I Will have to do that
I the cover off difficult to do I have bought pipes and fittings What was the issue with yours :+1:
As I mentioned my NC washer pipe was blocked on one side, just a slight trickle. All I did was remove that section of pipe and clear the pipe and refit it. Not had the washer pipes off the ND so I don’t know how they route, can’t imagine it’s anymore difficult than the NC, just remove the scuttle panel and they are there.
When you removed the scuttle panel is there an easy way to removed the screw covers on the corners without breaking them I have sent for some trim removal tools for studs etc. John
Each cover has 4 small tabs, 2 on each longer side. Trim removal tool will help not to distort the plastic cover.
I have removed mine a couple of times using the Flyin Miata YouTube video for their mesh filter as a guide to getting the scuttle cover off
Thank you so much I have more confidence in doing it now I tried are through the system this am but in think the issue lies with the washer jets John
