2017 ND sump plug size/alternatives
  1. My model of MX-5 is: __2017 ND
  2. I’m based near: __Lydney
Recently changed the oil on my MX-5 , the sump plug is a hex key type, i was thinking of replacing with a bolt type that i can torque correctly, anyone know of a good alternative all the ones i see are for earlier models but im unsure if the size is the same?
The later cars do have a bolt type sump plug
So if you speak to your local dealer you will be able to order one
