I have a 2023 Exclusive-Line. It is currently fitted with the standard Mazda brake callipers but I would like to upgrade to the Mazda-approved Brembo brake callipers (currently fitted to the Homura). Does anyone know if the Mazda-approved Brembo brake callipers can be fitted directly to the Exclusive-Line (I am also going to change the OEM alloys so these wouldn’t be a limiting factor)?
The brake discs are different as are the pads and associated fittings including hoses. Have a look here 2. CHASSIS AXLE SUSPENSION,BRAKE & STEERING | Mazda MX-5 Europe 10.2017 Parts Catalogs | PartSouq
Front Brake Caliper, Brembo, MX5 Mk4 & RF (mx5parts.co.uk)
Front Brake Discs, Genuine Mazda Brembo, MX5 Mk4 & RF – MX5 Parts
Front Brake Pad Set, Genuine Mazda Brembo, MX5 Mk4 & RF – MX5 Parts
Front Brake Pad Retaining Clip, Brembo, MX5 Mk4 & RF – MX5 Parts
Front Brake Pad Retaining Pin, Brembo, MX5 Mk4 & RF (mx5parts.co.uk)
Brake Hose, Front, Brembo, MX5 Mk4 & RF (mx5parts.co.uk)
May be a call to MX5parts would help.
PS The standard set up is more than adequate especially if you go for some upgrade in the pads. (Roddisons for example)
