I have a 25th Anniversary Edition MK3.75 with the retractable hard top.
When the hard top is being raised the top corners of the rear window frame have started rubbing in identical positions on both roll hoops marking the black roll hoop back. It is as if the window has for an unknown reason sagged a little just as it lifts to clear (or not in my case) the hoops and complete the lift.
I’m not sure how long this has been happening as I only noticed the marks on the hoops recently as it’s not often I’m behind the car when the roof is down. It is does not catch when being lowered.
I’m interested to know if anyone else has had a similar issue and, if so, what the fix was.
Roll hoops are neither use nor ornament IMHO - get rid. If you are really worried about roll overs, then fit a good roll bar. (This may also catch too) Otherwise, do without. May have been happening all the time, but as you say, you just noticed it. Not a problem I have fortunately.
