If a a late Eunos, it will have a 370mm cat and standard length cat back. If you fit a header from any US/UK/Europe based supplier, you will need a new cat to fit. All of these manifolds will come with a port for EGR; hopefully they should have a bung, as the Roadster won’t have EGR. Don’t get a Mk2 header; these won’t fit.
The “rule of thumb”; 4-2-1 will shift the torque down the range. 4-1 will move it up; hence 4-1 is more suited for the track, where you spend more time banging off the rev limiter. Thats presupposing the manifold has actually been designed by anyone. Racing beat have spent some time with their manifolds, getting the flows good, and that reflects in their price. Who knows with the Japanese headers; you kind of think they should , given the extortionate pricing. Chinese headers; which is pretty much everywhere else. Well, they are vaguely copies of Racing Beat headers. But the bends are quite right, the welding is scruffy. No one has optimised these. They might make car go better, they probably won’t. If you are unlucky, it will make the car drive worse.
Having said that, I have Chinese headers on my cars. One is from MX5parts, been on c. 14 years. It buzzed a lot compared to stuck, but is ok now. It went on at the same time as other parts, so can’t tell if it made a difference. After a couple of years, it cracked around one of the headers, and was welded for beer money
The other car has a no-brand header from a Sheffield supplier, but likely Chinese made. It went on to replace basically an identical header that had cracked through on the downpipe. It was cheaper to buy new than to get the old one welded up. I treated it as bling, making sure the header was alchol washed before it was fired up the first time (during the first time it warms, the stainless steel will passivate, or blue. If you have left greasy fingermarks on it, the grease will make into the steel, and it will look terrible. Clean, it will go a nice golden colour, and purply around the welds, and then stay like that.
When fitting a header, you will need to extend the wiring for the O2 sensor. Racing Beat sell a plug n play extension.
So, if you are buying one to make more power, buy from a supplier who can show you dyno charts, otherwise you are buying because you just fancy a stainless steel header.
Racing Beat has a nice article and charts:
http://www.racingbeat.com/mazda/performance/headers/4-1-header-development.html
One side effect is that a 4-2-1 header will quieten down an exhaust.
Busted v new (1.6)
New MX5parts 1.8 v OE
New 1.6, unheated
Blued
MX5parts adapter, required to mate manifold to Jap cat. Now ditched.
MX5parts manifold fitted, unheated. But I didn’t clean this one. After a year or so, not really golden.
Warning about used Jap manifolds; to reduce the buzziness of 1-piece headers, the Japanese often fit a piece of flexible tubing (Goodrich tubing). This stuff wears out and blows. Some sellers will ask a lot of money for a busted Japanese header because it is Japanese. But you really don’t know if in fact its just junk.
