Just been to see Kieran and he has gone out of his way to make this event great for us.
Free nitrogen fill for all attending, That’s right they will deflate you tyres and refill with Nitrogen for free ( this is worth a fiver on its own)
They are prepared to offer fluid changing on the day for a nominal fee (engine oil, diff oil, Gearbox oil and brake fluid) you will need to provide the oil and filters but they will do the rest.
Bring your own brake pads and they will fit them again for a nominal fee
If you want new tyres then Kieran is offering 35% off all tyres plus a fiver for fitting ( Pirelli P1 185/60 14 £38 + Vat or 195/50 15 £39.24 + Vat) He can get any make but needs to know in advance please.
Tyre changing and wheel swapping
Exhaust Fitting
Free Tea and Coffee
Plus of course the main reason for going the full 4 wheel Geometry setup (Camber, Cast and toe) for £30.00
Basically he has opened the workshop for us and us alone so please support this event.
I have took some pictures below of the facilities.
Waiting area with live viewing of the geometry set up.
The main benefit of Nitrogen in the tyres is its stability, tyre pressures rise as the tyre gets hot thus affecting the handling charactaristics of the car. Formula 1 have been using Nitrogen since 1992 because of its stability.
Nitrogen maintains tyre pressure 3 to 4 times longer than air filled tyres.
The Benefits are
Safer Motoring - Better Road holding and handling
Longer Tread Life - Up to 25% increase in tyre life
Reduced Fuel Consumption - Up to 5% reduction in fuel consumption
No Oxidation - No water vapour or oxygen means no corrosion of wheels
No problem to bring both cars as there will be plenty of time, just let me know.
Add me to the list for this. I can’t believe the roads are as slippery as they appear to be right now and getting the alignment checked and sorted would certainly help.
The whole day sounds like it is going to be a tremendous success. Unfortunately it is 220 miles each way according to Google Maps. Wish someone further North would offer the same service; I would be there in a shot.
Pls put my name down for this (afternoon prob by the time I snowplough over from the Fens…) as my wheels haven’t been touched for a while. Wymondham? Will bring my passport and may pick up a rose bush on the way home, lovely.
I’d like to pop along to this, but as i’ll be picking up a brand new sport black mx5 less than a month before this date (this saturday in fact) i’ll not really be looking at getting anything done, it’s more that it looks like a nice drive out
